RINGS FOR MW 4 1/16 PISTONS
Paul Knecht
06-23-2006 10:10:12
I need a set of rings of a MH 44 with M&W 4 1/16 pistons.
Tom Dold
06-24-2006 12:25:09
 Re: RINGS FOR MW 4 1/16 PISTONS in reply to Paul Knecht, 06-23-2006 10:10:12
Paul
Hastings 2C-7595 should be the right ring set for MW 4-1/16 overbore.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
J Schwiebert
06-24-2006 03:59:18
Take your ring dimesnions with you and also check for a 4 inch bore 60 over set as the 2-1/2 thousands difference between 4 inch = 60 and 4-1/16 at 4.0625 will not make a difference. You need some ring catalogs.
massey333
06-23-2006 13:48:41
Hasting or Perfect Circle,POW'R SEAL*,maybe this site.They are out there and avalible.
