Need help with MF 65 PTO leak
Paul Worsey
07-14-2000 15:46:28
Have Massey 65 with PTO leak. Has been into shop to be fixed but problem is reoccuring. The problem appears to be that the PTO spline slides in and out of the PTO housing excessively (well over one inch). When I lift the bush hog the PTO shaft pushes the spline into the casing sufficiently enough for the gear teath to push too far back into the rubber bushing/boot. This then allows oil to exit via the teath wells.
My manual does not have enough detail to see if there should be a spring behind the spline to keep it pushed out, or if there are any extra parts that I am missing. Maybe I might have the wrong spline? Any one know what the problem is?
