FE-35 Diesel Wiring Diagram
Dean
06-20-2006 18:54:53
Might anyone have a wiring diagram for a FE-35 with Perkins diesel?
I recently discovered that the generator on this tractor is not charging. It still has the original Lucas generator and voltage regulator but the wiring has been farmerized.
I discovered one wire connected to the voltage regulator that is simply taped off. Both the armature and field wires are connected to the voltage regulator so I expect that this one should connect to the battery but am not certain.
Compounding the problem, this tractor was apparently built with neither ammeter nor charging indicator lamp.
Thanks, in advance.
Dean
Smokey K
09-26-2006 15:03:45
 Re: FE-35 Diesel Wiring Diagram in reply to Dean, 06-20-2006 18:54:53
I'm having the same exact problem. Also have taped off wire.
Could use wiring daigram
Thanks in Advance
C. T. in Oklahoma
06-22-2006 06:18:24
Dean, I have Big Dean's cd and the diagram is on it. I would be glad to send it to you, just let me know where to send it. C. T.
Dean
06-22-2006 10:37:35
 Re: FE-35 Diesel Wiring Diagram in reply to C. T. in Oklahoma, 06-22-2006 06:18:24
Thanks, CT. My email is open. Send a message and I will reply.
Dean
JJ. in B.C.
06-21-2006 14:11:52
Dean, give John (UK) a shout on the Fergie board, i'm sure he can come up with one.
JJ.
Dean
06-21-2006 17:20:41
 Re: FE-35 Diesel Wiring Diagram in reply to JJ. in B.C., 06-21-2006 14:11:52
Thanks, JJ. Will do.
Dean
