135 shut down update
Ken Ohio
06-20-2006 03:59:18
Went to the farm yesterday. To stop the leak in the line from the tank to the fuel bowl, I wrapped string around the line between the o-ring/"olive" and the nut. It's only temporary until I can find a new olive but it worked.
Bled the system and had good flow from the bleeders. Still wouldn't run. Repeated this for 1/2 hr. Finally had to crack the injector lines and crank till I had good flow from the fittings, and it started. Bush hogged for 1 1/2 hr. with no problems. At least it's out of the field and back in the shed.
Why wouldn't opening the bleeders take the air out? Why did I have to crack the injector lines?
Ken Ohio
06-21-2006 04:21:20
 Re: 135 shut down update in reply to Ken Ohio, 06-20-2006 03:59:18
Thanks guys. Glad it's a common problem, and not unique to this one.
Jerry/MT
06-20-2006 21:10:47
usually when you get air into the fuel system, you have to bleed the system to the hightest point. The air bubbles are lighter than the fuel and rise plus you pump pushed air into the fuel injector supply lines.
mowr
06-20-2006 08:01:01
The bleeders can only evacuate the air trapped where they are (filter ass'y, pump, etc.), not the air in the injector lines.
MF Poor
06-20-2006 05:03:52
Quite simple actually. You still had air in the system. When the lift pump went out on my 150, I had to bleed the injectors (well, ONE anyway) to get it re-fired.
