what kind of fluid for a massey 50 ?
Tim Cochrane
06-19-2006 10:00:21
what kind of fluid does the tranny / hydraulics use in a massey 50? thanks
phil(va)
06-19-2006 10:41:43
 Re: what kind of fluid for a massey 50 ? in reply to Tim Cochrane , 06-19-2006 10:00:21
I am pretty sure your 50 is the same as the Fergie 40 and the 35.... If you fully drain all drain holes, it takes 8 gallons of mineral oil, or GL-1 in today's terminology. That is NOT normal gear lube (which is GL-3,5), but you can find GL-1 at many tractor supply stores, at NAPA, and sometimes even at WalMart in rural areas. It's about $25 for 5 gal. I would not fill completely until I let it sit for awhile, like overnight, as it takes awhile for the fluid to settle properly through the baffles. Also, it takes awhile for it to drain, even with all the drains open, and it's possible you may not get it all out. Hope that helps.
