MF165 GEAR SHIFTER LOCKED IN REVERSE
GOWENS
06-18-2006 09:36:24
WHEN I WENT TO SHIFT MY MF165 INTO 2ND GEAR IT DROPPED DOWN INTO REVERSE AND NOW THE SHIFTER WILL NOT MOVE AT ALL !!. TRACTOR RUNS FINE BUT WILL ONLY GO IN REVERSE. ANY HELP WOULD BE GREATLY APPRECIATED. THANK YOU.
Brian Huskins
10-19-2006 05:35:34
 Re: MF165 GEAR SHIFTER LOCKED IN REVERSE in reply to GOWENS, 06-18-2006 09:36:24
Thanks worked in 30 sec, Thanks for the information
C. T. in Oklahoma
06-19-2006 07:15:25
Don, I don't want to sound like a smart alec, but if Big Dean says it, there is no reason to doubt it. I wasn't quite as fast as you the first time, but the second time, I think I did it in about a minute. I am careful to apply downward pressure now, so it won't happen again. C. T.
Donald Tucker
06-18-2006 16:15:16
It Works! It Works! It Works! Fixed mine in about 63 seconds!!!!
Don Tucker
06-18-2006 15:37:08
I have the same problem with a 68 year model 135. Do the same procedure apply to my tractor. I just bought the tractor and moved it off my trailor when it locked up. What a way to start huh?
Big Dean
06-18-2006 11:22:12
Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. If hung in second or third gear you have to pry on the shift fork you can see through the filler hole. If hung in second pry the fork toward the front of the tractor. If hung in third pry the fork toward the back of the tractor. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
Cause for Shift lever hang up
The transmission main shaft lever hanging up is very common on most models of the MF tractors. The shift lever is held down by a spring & when you start to shift it you will unconsciously lift upon the lever. This causes the shift lever to go into the other shift fork on the other shift rail. That rail cannot be moved because of the lock on the back of the transmission to prevent it from going into two gears at the same time. Once you have both shift rails in the neutral position you can then move the shift lever. If you will use the palm of your hand When changing gears to push the lever into neutral then get hold of the lever to put it in the gear you want it in. Shifting it that way it will not hang on you again.
