MF 2705
K. McGee
07-12-2000 21:37:41
What is the history on the MF 2705?
Is it a good sound Tractor or not?
What is the history problem of this tractor if any?
What trans. have had problem with?
Bob
07-13-2000 06:57:34
 Re: MF 2705 in reply to K. McGee, 07-12-2000 21:37:41
The 2705 ia rated at 120 HP. It has a 6 cylinder engine. The cab has great view. Very good fuel economy. Good power. But the 24 spd. trans. is it's weak spot. I think overall it's a good tractor.
tim wheaton
11-07-2000 17:37:50
 Re: Re: MF 2705 in reply to Bob, 07-13-2000 06:57:34
can you give any info on mMF2705 transmission, convert to 8 speed from 24 speed
Dave
08-01-2000 19:34:59
I have had a 2705 for about 4 years. I think its a pretty good tractor except for the power shift which can give you problems. Mine needs rebuilding. I like it as baler tractor, the pto and hydlics are good. They will work alongside most other makes of same size and age. Dave
Bob
08-05-2000 07:45:18
 Re: Re: Re: MF 2705 in reply to Dave, 08-01-2000 19:34:59
If you don't need the additional shifting capabilities, you can replace the power shift with a straight shaft and make a striaght 8 speed out of it, and you won't have anymore problems with it again. I have a 2805 with a staight 8 spd. and get along good with it in the fields.
Dave
08-05-2000 18:51:11
 Re: Re: Re: Re: MF 2705 in reply to Bob, 08-05-2000 07:45:18
Bob, thanks for the tip about replacing the powershift with a straight shaft. Sounds like a good idea, Iv'e been running with only high shift for about two years and I get along fine. The only problem I can see is how would the reverse work? Dave
Bob
08-07-2000 09:47:32
 Re: Re: Re: Re: Re: MF 2705 in reply to Dave, 08-05-2000 18:51:11
Dave My 2805 has a stop placed on the power shift lever so that you cannot shift it down. It acts like a forward and reverse shuttle shift. A fellow by the name of Big Dean is pretty sharp on this stuff. You could post a question to get a little more detailed answer. I think he is a Massey tech.
