1105 low hydraulic flow question
Todd(Ohio)
06-07-2006 19:37:21
Wondering if it is feasible to rebuild the pump at the front of the tractor or buy new or rebuilt? Flow is down and pressure barely picks up a 6 row planter when loaded with seed and fertilizer. I have serviced the main screen at bottom of diff and the filter at the front of the tractor. Pump is very noisy. Seen quite a bit of brass in the filter when changing the filter. Also is it normal for the 3 point to leak down when sitting for a day?
barnrat
06-08-2006 17:29:25
 Re: 1105 low hydraulic flow question in reply to Todd(Ohio), 06-07-2006 19:37:21
With the brass in the pump. Sounds like your brakes are going bad also.
Ranger Ted
06-08-2006 11:12:17
Yes, the pump can be re-built. You can buy a kit to re-build it from Massy. I took my to local dealer to have it done a few years ago on my 1100. I think yours is the same pump. ( The pump is HEAVY ).
