Lift pump symtoms
MF Poor
06-06-2006 08:52:38
I have reason to suspect the primary fuel pump is failing on my Perkins diesel MF 150. From time to time, it seems to quit pumping at low idle. The injector pump then will loose its prime. I go through the entire proceedure to purge air. Then things go like normal for a few weeks. It did it again last night. Just open the bleed screws on the injector pump, get fuel there, then crack open an injector, and with-in 10 minutes, she"s back up and running. I can"t let the engine idle when I first start it up. (Doesn"t do this after engine gets warm)
I"m suspecting the lift pump, but don"t know that"s it for sure. Any thoughts?
