Wanted-Used/Salvage Rear Main Bearing Cap for Perkins 3-152 Gas/Diesel engine
John Miller, II
07-10-2000 13:23:16
need a good used rear main bearing cap (the one that holds the thrust washers in) for a Perkins 152 engine, gas or diesel is the same.
nparkinson
03-09-2001 11:26:18
 Re: Wanted-Used/Salvage Rear Main Bearing Cap for Perkins 3-152 Gas/Diesel engine in reply to John Miller, III, 07-10-2000 13:23:16
I have noticed that you require back main caps for a 3 cly perkins. As you are aware that all main caps are lined bored so if you secure a cap you may needit line boreing. If you require a quote for a new or second hand block please e-mail me with thwe full engine number and i will quote you
John Miller, III
07-11-2000 07:15:15
Found it at Quality Farm & Country! Thank you!!!
