Mf-165 hydraulics
s.carter
07-10-2000 13:20:44
I have a 165 that I have to raise and lower the 3 point hitch by using the draft controll instead of the positioner.If I put the poisitioner all the way down neither work but if it is in the travel poisition the draft controll will work the hitch.Any suggestions on what is wrong and how to fix it?????Any info will be greatly appreciated.THANKS
bbott
07-11-2000 13:03:56
 Re: mf-165 hydraulics in reply to s.carter, 07-10-2000 13:20:44
What happens when you have the Draft
all the way back (UP) and you move the position lever up & down ?
In the above mode, the position lever should raise and lower the 3 point to whatever position
you set it and stay there.
That's the way it's supposed to work.
You either use draft OR position. Whichever one your'e not using goes all the way to
the back.
bb
