mf 178. Replace standpipe orings/three point won't
fromky
06-05-2006 08:42:56
Well, as you guys know. I have replaced standpipe orings and put everthing backed together and the three point will not go down. When you start the tractor, the arms go up and won't come back down. Should I just drop off @ the dealer or is there something I am missing.
bg148
06-05-2006 14:08:21
 Re: mf 178. Replace standpipe orings/three point w in reply to fromky, 06-05-2006 08:42:56
I recently had a similar problem after replacing the lift cover. Lift went all the way up, system went to constant pumping and would not drop. I started to unto the respose control access plate to see what was happening and as I undid it the arms dropped. Somehow in putting on the response cover, I must have put it on wrong and it interferred with the control linkage. Put it back on (with care!!) and hey presto lift worked fine.
bg
