Removing rear end from trans housing
wayne
07-10-2000 11:24:51
I have a pony with an oil leak where the rear end bolts to the trans housing.There are 4 bolts holding the two housings together and it is a static seal with a gasket that should be easy to fix..Problem is what will I see when I remove the 4 bolts and pull the rear end backward...Is there a long shaft that goes all the way up to the transmission or some sort of coupling in there..It is several feet from the bolted joint to the transmission. Will I get into any trouble here??
