Multi-power still not right
MF 35 in WV
06-04-2006 13:50:07
As suggested in previous post tried the adjustments to no avail. Still shifting on its own when fluid is hot and has no engine breaking as it does upon ititial startup.
Big Dean
06-05-2006 08:47:46
 Re: Multi-power still not right in reply to MF 35 in WV, 06-04-2006 13:50:07
You have either the the seals in the clutch pack are bad or the multipower pump is weak or maybe both when the oil gets hot and thins down it is bypassing someplace either in the clutch pack or in the pump. The way the multipower is designed when the pressureer drops below what it take the close the clutch pack for high range it will go into low range regardless of where the shift lever is at. Hope This helps
MF 35 in WV
06-05-2006 14:40:28
 Re: Multi-power still not right in reply to Big Dean, 06-05-2006 08:47:46
Is there repair parts still available thru Massey?
Also I want to thank everyone for their responses for this post and the last as well as any future ones.
Big Dean
06-05-2006 17:01:02
 Re: Multi-power still not right in reply to MF 35 in WV, 06-05-2006 14:40:28
Parts are available for them from MF dealers and also from some of the after market place. I just completely rebuilt the clutch pack and replace the pump in one I could not find one of the old style pimps so I had to get the late style pump and late style pump mount. The parts cost right at a $1100 for these items need to rebuild it. this was about 3 months ago. If everything is not replace that it needs replaced it will not last long. You can buy a transmission with out Multipower for about $800 to $900 that will bolt right in place of the multipower transmission.
Luke Przybyla
09-21-2006 18:13:25
 Re: Multi-power still not right in reply to Big Dean, 06-05-2006 17:01:02
Is there anyway to convert a multipowered transmission into a regular transmittion.
MF 35 in WV
06-05-2006 22:25:44
Thanks Dean, with the cost of fixing I may start looking for a transmission without the multi-power as I don't really like the benefits over the consequenses of not having engine breaking. Here in West Virginia everyplace I go is either up or down and having engine hold back is mandatory to keep you right side up. Thanks for your help.
Bob N.Y.
06-04-2006 16:52:12
Are you saying it slips into low on its own? That could mean a weak auxillary pump. Better talk to Big Dean.
