Massey Ferguson 3060 wiring diagram
Paul Stanford
06-04-2006 08:07:01
Hi,I have a MF 3060 and the P.T.O shaft the high and low ratio on the gears has stopped working please can anyone offer any advice.
Many thanks,
Paul
richard in nz
06-06-2006 01:37:57
 Re: Massey Ferguson 3060 wiring diagram in reply to Paul Stanford, 06-04-2006 08:07:01
Have you also lost two/ four wheel drive (is tractor stuck in 4WD) if fitted, Diff lock, and pto brake? and speedshift aswell?
Paul Stanford
06-06-2006 02:35:22
 Re: Massey Ferguson 3060 wiring diagram in reply to richard in nz, 06-06-2006 01:37:57
Hi Richard,
the tractor is only two wheel drive but we have lost all the things you said,please can you help with this,
Many thanks,
Paul
richard in nz
06-07-2006 03:50:39
 Re: Massey Ferguson 3060 wiring diagram in reply to Paul Stanford, 06-06-2006 02:35:22
Oil for all these services is supplied from the distribution valve bolted under the bonnet. That is fed from the outlet pipe from the power steering unit on the front bulkhead of the cabin. The oil then flows along a pipe down the right hand side of the tractor. It is teed off to supply the speedshift solenoid and the Hi-Lo selector valve, the main feed then goes to the Right hand side cover where you will see a row of solenoid valves. The pressure in this line should be 17bar. The solenoids are (from the top) pto brake-orange wire. pto clutch- green wire, diff lock- blue wire, 4WD- yellow wire, and Hi Lo range- grey wire. If you have a 17 bar feed pressure then check the power supply to the solenoids with the engine running, charge lamp and engine oil pressure lamp, and transmission oil prssure lamps ALL working and going out or the Autotronic computor will be in sleep mode. Let me know what you find as it starts getting complicated after this, but I have all my 3000 sereis training notes still at hand so should be able to get you sorted. Check the pressure anywhere between the distribution valve and the side cover first, must be 17 bar (multiply by 14.7 for p.s.i.) The speedshift solenoid is by the clutch housing on the right hand side-green wire. The filter blocked vacuum switch is blue wire andthe Hi-Lo switch on the selector housing is Live-red, Return white.
