massey 50 will only run with choke on ?
Tim Cochrane
06-02-2006 07:14:17
my massey 50 was running fine till today now it will only run with the choke on , works great with it on tho ? any suggestions ?
Jerry/MT
06-02-2006 10:07:54
 Re: massey 50 will only run with choke on ? in reply to Tim Cochrane , 06-02-2006 07:14:17
Verify that you have a good spark( a fat bluish spark) and if you don't, find out why. If your spark is good, look for an air leak that's downstream of the carburetor metering section (i.e. at the throttle shaft, the carb to manifold connection, and/or the manifold to head connection.
Jerry/MT
06-02-2006 10:10:08
 Re: massey 50 will only run with choke on ? in reply to Jerry/MT, 06-02-2006 10:07:54
Forgot to mention that you should also verify that your carb adjustments are correct. Don't know what they should be for a Massey 50 but they'll be in the owners manual or the shop manual.
