165 Steering shaft replacement
Ga Plowboy
06-01-2006 02:09:31
Hi: We are trying to upgrade the old sytle two piece steering shaft/pitman bracket on a 1965 model to a later style like I have that is one piece. The bushings are the same, and we are wandering if the new one piece shaft will work. This is the vertical shaft that the cylinder pushes around to steer the tractor. The 1965 165 had a shaft and a piece that attached to the bottom of the shaft on one end and the tie rods attach to the other end. Thanks in advance; barney
