TO35 won't shift out of 3rd
David Dawson
05-30-2006 19:17:46
HELPPPPP PPPPP PPP! My son was hogging yesterday stopped to back up but couldn"t shift out of 3rd gear. Hi/Lo shifts great. Anybody have any ideas? I"m sure I"m not the first to happen. Thanks for any help.
David
Big Dean
05-30-2006 19:59:12
 Re: TO35 won't shift out of 3rd in reply to David Dawson, 05-30-2006 19:17:46
Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear.
If hung in second or third gear you have to pry on the shift fork you can see through the filler hole. if hung in second pry the fork toward the front of the tractor. If hung in third pry the fork toward the back of the tractor. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
