MF1135 Turbo
DuronDon
05-29-2006 12:16:16
I just pulled the turbo off the 1135 I just purchased and found it had an Airesearch TO4 on it. My manual says that the 1135's used a Holset Turbo and the 1105 used an Airesearch Turbo. Did I get ripped off here and should I be looking to purchase a Holset Turbo? Someone told me that the HP difference on the 1135 vs 1105 wasn't from the turbo, it was from the Injection Pump and injectors. Could someone help me out on this one?
Thanks.
barnrat
05-30-2006 17:29:48
 Re: MF1135 Turbo in reply to DuronDon, 05-29-2006 12:16:16
I've seen this before. Some one may have replaced with the wrong turbo. Or swaped one off of an 1105 in a pinch. It should work the same. Like you said the extra power on the 1135 come from the fuel system(2940psi compared to 2645psi) and the timing(30 degrees compared to 26 degrees). The only way to truly find out is to cross reference the pump numbers or put it on the dyno. One another not so scientific method is an 1135 likes to blow lottsa black smoke when fully loaded. An 1105 is usually pretty neat and clean under full load.
DuronDon
05-30-2006 19:08:07
 Re: MF1135 Turbo in reply to barnrat, 05-30-2006 17:29:48
Thanks for the help.
