MF50 PTO binding
Dan S (NY)
05-27-2006 06:06:52
Having problems with a new PTO shaft installation on my 1959 MF50. Has 2 stage clutch and engine/ground PTO. The PTO shifter is very hard to move, and after mowing for 20 minutes, it became EXTREMLY hard to move. Got the PTO disengaged but then could not get it to move again. Got to the point I was worried about breaking the lever if I tried any harder. Once it sat overnight I could move it again but still very stiff. I have done the pump alignment procedure several times as outlined in the service manual and it doesn�t make any difference. Turning the PTO shaft by hand is also pretty stiff, with a slight binding feel at one point in the rotation. When I replaced this shaft, I also replaced both needle bearings so I know they are good. The rear bearing had no play and spin freely out of the tractor. I had the slide coupler out of the tractor before putting the shaft in and it slid fine on the splines at the pump end of the new shaft. The only thing I can think of at this point is the coupler is binding in the rear housing bore it slides in and out of. I would appreciate any thoughts anyone has on this problem. My thinking at this point is the splines on the shaft where not machined true to the centerline which would cause the coupler to be slightly off center and to bind in the housing. I may have to bite the bullet and buy another new shaft. Thanks for any help, I�m kinda frustrated trying to figure this out.
Dan
