MF 41 dynal balance mower
Greg Burns
05-25-2006 19:25:42
I have a dyna balance 41 mowing machine that was given to me that the bearings on the main shaft where the cams are that were pretty badly damaged. I took the shaft out and decided to sepnt the money to replace all the bearings on the shaft which was costly. I put the bearings and shaft back together and hooked the mower up and turned it by hand everything seemed ok. I went and mowed probably a half acre of heavy grass and checked the two bearing on the cams and they were hot enough that I did not want to leave my finger there very long. I greased them again and cut a little longer but the bearings that pivot the cycle bar and the counter balance are getting quite warm. Is this the nature of the MF 41 dyna balance mower or do I have something wrong the mower seems to cut great Any comments or suggestions would be appreciated.
unclemerle
05-27-2006 04:10:37
 Re: MF 41 dynal balance mower in reply to Greg Burns, 05-25-2006 19:25:42
Greg
The mower should cut all day long and the bearings should only be warm from normal usage. I can"t help you as to what is wrong as I never had to take ours apart and don"t know what it looks like inside.
Good Luck Merle
