MF50 trans
chris blair
05-24-2006 09:46:43
My MF50 gets stuck in gear sometimes, and I have to remove the transmission top cover to unstick it. This keeps on occuring now, and I was wondering if anyone might know what a long term fix might be. Any help greatly appreciated. Thank you, Chris Blair
RegoR
05-25-2006 06:41:49
 Re: MF50 trans in reply to chris blair, 05-24-2006 09:46:43
Hi Chris;
I've had the same problem with my TO-35. I replaced the detent plungers and springs and that seems to have corrected it. Also, I am more careful when shifting, so that might help as well.
To get things lined up again, you should be able to access the shifting forks using a long screwdriver through the oil filler plug on the tranny cover, eliminating the need to remove the cover.
As for unauthorized use, pocket the key! ;-)
Good luck,
Roger
C. T. in Oklahoma
05-25-2006 08:21:48
 Re: MF50 trans in reply to RegoR, 05-25-2006 06:41:49
Roger, Thanks, I missed that thing about the transmission plate, of course the oil filler plug is the way to go. I have a small pry bar that worked perfectly the times when it happened to me.
C. T.
C. T. in Oklahoma
05-24-2006 11:16:47
I don't know about a fix, but Big Dean recommends applying a little downward pressure when changing gears, and that has pretty much resolved it for me. I just place my palm on the ball and apply a little pressure when shifting. C. T.
Chris Blair
05-24-2006 12:33:19
 Re: MF50 trans in reply to C. T. in Oklahoma, 05-24-2006 11:16:47
Thank you for your response! I shall incorporate that into my normal operating procedure and see how it goes. The tough part will be keeping my kids off that thing when I'm not around!! Thanks! Chris
