Multi Power on a MF156
Don Au.
05-22-2006 06:03:57
I�m looking at a used MF 156 with the Multi Power feature. Can someone explain how this works in the transmission and what it would take to repair and if it�s worth effort?
lonestarjeff
05-22-2006 13:55:28
 Re: Multi Power on a MF156 in reply to Don Au., 05-22-2006 06:03:57
On my 165 the multi-power is engaged by a hydraulic clutch that is actuated by a small aux. pump sitting on top of the main belly pump. From what I've read here the problems w/ it are usually linkage between the lever & pump, not the pump itself. Problem is, some of the linkage is hard to get at w/o splitting the tractor.
It's a great feature to have, adds 6 more speeds, gives you engine breaking in Hi, holds position on a hill w/o using brakes(in Hi).
So far(knocking on wood), mine has been trouble-free.
Jeff
