MF three point lift
jra
05-21-2006 22:29:36
I just got a MF 20 Turf Ind. tractor. I have some books orderd for it but they haven't come in yet. I think it's about a 1973 modle and has a 3 cyl. gas engine It had a bush Hog with it, but the three point lift doesn't seem to work like it should. I can lift the mower ok if I set the position control lever all the way up and then use the draft control lever to lift the mower. If I set the draft lever in the full raised position the position control lever won't lift or lower the mower. Don't seem like the position control works. It don't have any other valves or any hose outlets on it. Anyone have any ideal what could be wrong, what to look for?
mowr
05-22-2006 20:39:16
 Re: MF three point lift in reply to jra, 05-21-2006 22:29:36
Your manual will tell you how to set the adjustable stop to block the lever from coming all the way up into the 'constant pumping' range. A time for using that position would be when running a loader off the tractor hydraulics.
Big Dean
05-22-2006 20:37:47
There is a piece of linkage in the liftcover that will pop out of place in those tractors causing the Position control not to work. I have a picture that show it and how it should be located.
smockey2
05-22-2006 14:46:10
check out Big Dean Austins site as he has all the doco you need. He is often on this site.
