MF 165 oil and exhaust out the valve cover vent ?
MT of KY
05-17-2006 01:02:47
My brother in law"s diesel 165 is blowing exhaust out of the valve cover vent all of the time. The last time he mowed for about 2 hours and then it started blowing puddles of oil out the vent. After it cooled off we started it back up, no oil. Anybody have any ideas?
j i p
05-24-2006 08:38:57
 Re: MF 165 oil and exhaust out the valve cover ven in reply to MT of KY, 05-17-2006 01:02:47
had same prob with my 165 .
it was all 4 top piston rings broken , some bits were melted into the piston. she was still running ok with that. but poor to start
j p uk
TomTX
05-18-2006 06:01:20
Time to perform a compression test. Write down for each cylinder. Add tablespoon of oil to cylinder and repeat the test. Write down again. compare. Analyze difference among cylinders, and change with the oil added. This will let you know if rings are worn out, if one cylinger is bad, etc. May be time for a rebuild. Tom
marlowe
05-17-2006 14:27:16
it's not exhaust it's blow by from bad rings and or valve guides. dose it start hard?
MT of KY
05-18-2006 00:54:22
 Re: MF 165 oil and exhaust out the valve cover ven in reply to marlowe, 05-17-2006 14:27:16
Yes it starts hard when its cold, but not bad after it warms up. I"ve also got a 165 and his doesn"t start as good as mine.
