MF 65 Lower Radiator Hose
Mark Watkins Ky
05-14-2006 06:33:33
Just replaced the radiator on the MF65. Is there any way to increase the clearance between the inner fan belt and the lower radiator hose? Seems like they are really close but not touching.
David Bloodwood
05-14-2006 17:33:10
 Re: MF 65 Lower Radiator Hose in reply to Mark Watkins Ky., 05-14-2006 06:33:33
If your problem is that the hose is too far forward behond the belt, I fixed that problem on mine by shimmying the bottom end of the hose back off the radiator inlet about 3/8". Still has a good seal on the inlet, and shifts the middle section of the hose away from the back of the belt.
David
Mark Watkins Ky.
05-14-2006 17:39:50
 Re: MF 65 Lower Radiator Hose in reply to David Bloodwood, 05-14-2006 17:33:10
Thanks, Ill give it a try.
