First Fergie
Therese
04-07-1998 10:17:33
I recently purchased a TO35 and I'm having problems
engaging the engine PTO. It goes into gear but
only after much force and a terrible grinding and goaning. I did as all good Fergie owners
should, and consulted my manual. If I understand
correctly there are 2 positions with the dual clutch (hence its name. I can only find one. Is the obvious answer that I need to adjust
the clutch or am I missing a more obvious answer?
Please help the snow is gone and I need to do the
spring plowing.
Jack in NB Can
04-07-1998 13:44:16
 Re: First Fergie in reply to Therese, 04-07-1998 10:17:33
Great tractor; common problem.
First, check free play - should be about 3/4" or so.
Next is adustment of the PTO clutch itself. This can be done by removing
the plate under the flywheel, and adjusting the PTO clearance with the three bolts accessible with difficulty from beneath. The factory manual suggests .090" on these; we've had better success with .055 - .060".
I strongly recommend picking up a copy of the I&T shop manual - $20 from Central Tractor - shows the appropriate bolts.
If you'd like more info, drop me an e-mail.
Jack Wetmore
Greg
04-09-1998 13:43:41
 Re: Re: First Fergie in reply to Jack in NB Can, 04-07-1998 13:44:16
: I strongly recommend picking up a copy of the I&T shop manual - $20 from Central Tractor - shows the appropriate bolts.
What is an I&T Manual? Is Central Tractor the same store as the Farm and Country in Des Moines? Just purchased a Ferguson 30 (TO? TE?) no manuals or literature of any kind. I need anything I can find to help me get her up to her original beauty.
Thanks,
Greg
Jack in NB
04-10-1998 05:21:59
 Re: Re: Re: First Fergie in reply to Greg, 04-09-1998 13:43:41
: What is an I&T Manual?
A shop manual - illustrated, detailed, accurate - published by Intertec.
:Is Central Tractor the same store as the Farm and Country in Des Moines?
Yup.
: Just purchased a Ferguson 30 (TO? TE?) no manuals or literature of any kind. I need anything I can find : to help me get her up to her original beauty.
Great tractors.
Try the MH site ->Link
ps. Your email address above doesn't work!
Jack
