MH50 exhaust manifold gasket
shifter
05-12-2006 18:50:27
I have a leak in my exhaust manifold gasket and it is near enough to the gas line that it boils the gas and causes the engine to stall out under heavy load when the temperature is up around 80 deg. It runs fine cool. There is a heat shield in place but that doesn't do the trick. I hear this leak and feel the heat. I looked in the parts section and didn't see a single gasket for the manifold. Do I have to purchase the entire gasket set for the Continental gas engine?
Paul in AZ
05-13-2006 05:34:14
 Re: MH50 exhaust manifold gasket in reply to shifter, 05-12-2006 18:50:27
I believe you can get just the manifold gasket from NAPA.
shifter
05-13-2006 08:16:43
 Re: MH50 exhaust manifold gasket in reply to Paul in AZ, 05-13-2006 05:34:14
Thanks Paul, I called them and they located one for me in 5 minutes.
