Pony hydraulics
Stuart brogden
05-12-2006 12:29:35
I bought a Pony that has several problems . The lift ram is off the tractor , the lines were cut and compression fittings put on it . The pump is still on the tractor . I'm trying to get it to run and don't want to run pump dry . Would hooking the two hydralic lines together be a good idea , would this allow some flow thru pump . I assume one line is the supply and the other the return.
Jason(Pa.)
05-14-2006 05:59:22
 Re: Pony hydraulics in reply to Stuart brogden, 05-12-2006 12:29:35
What you want to o should work. No you never want to run a pump dry if you are going to save it. I don't think anything would go wrong if you ran it with both lines plugged,just make sure there is oil in it,but do what you were going to do to be on the safe side.
