MF 65 3 point hitch drops
saa
05-11-2006 08:13:35
BIG DEAN ????? The 3 point hitch on my MF 65 drops while running or mowing. There are no visible leaks. Any ideas what is causing it? Thanks in advance.
Big Dean
05-13-2006 06:34:55
 Re: MF 65 3 point hitch drops in reply to saa, 05-11-2006 08:13:35
Does your tractor have a remote valve in front of the seat on the right side of the liftcovrver? Which lever or levers are you using to raise and lower the three point with this could make a big difference in what is causing your problem.
DavidP, South Wales
05-11-2006 15:18:42
Hi,
Does the linkage drop and then come back to its starting point, and then drop again?
DavidP
saa
05-12-2006 05:38:55
 Re: MF 65 3 point hitch drops in reply to DavidP, South Wales, 05-11-2006 15:18:42
Thanks for the reply. Once the hitch drops, it doesn't come back up unless I raise it with the lever.
DavidP, South Wales
05-12-2006 11:03:50
 Re: MF 65 3 point hitch drops in reply to saa, 05-12-2006 05:38:55
Hi again,
Is the position control working normally? That is a small or large movement translates into a similar movement on the linkage. Do you control your mower etc with the position control lever?
Any more info that you have on the problem would be useful.
DavidP
