MF 165 hydraulics
john polson
05-08-2006 12:29:59
i have early 165 left hand exhaust.
hydraulics work good but seem to be down on power. a friend has one and its the same.
is this a common prob , can it be sorted by ajustment or is it a repair /replacment of pump
Big Dean
05-08-2006 19:15:27
 Re: MF 165 hydraulics in reply to john polson, 05-08-2006 12:29:59
The MF100 and MF200 series tractor have a problem with the master control spring getting weak causing them not to lift a heavy load. I have a picture that shows how to remove the top link from between the liftcover and the implement and connect a chain between the differential housing and the implement to check to see if the Master control spring is causing the weak lift problem. If you will send me an email address I will email it to you.
