Removing Glass From Cab-1135
DuronDon
05-07-2006 18:11:06
Planning a rebuild of my 1135 and I'd like to remove all glass from the cab for painting. Anyone done this before? Are there any special tools needed? Looks to me like if I just use something thin to pry the rubber back I should be able to force it out but I'm not sure how I'd get it back in. Any help would be appreciated. Thanks.
Dave Sherburne NY
05-08-2006 18:38:36
 Re: Removing Glass From Cab-1135 in reply to DuronDon, 05-07-2006 18:11:06
I once had a broken window in an Oliver/Hiniker cab
It was held in a rubber molding same as my 85 GMC
truck which has on the outside, a rubber strip in the molding. You remove that rubber locking strip, and the window becomes loose, and then you can get it out easily. The tough part is putting
it back in, the locking strip that is. It can be
done without the special tools tho.
DuronDon
05-11-2006 16:39:06
 Re: Removing Glass From Cab-1135 in reply to Dave Sherburne NY, 05-08-2006 18:38:36
Thanks for the help. I'll give it a try.
