Hard to start MF65 Diesel
daleevr
05-06-2006 19:45:09
I have a MF65 diesel that has had a good cleaning, replaced all filters, glow plug, new fuel pump, gas tank cleaned out, new fuel shut off valve and bled the fuel system countless times. Runs great but will not start without either. Very hard to start even after you have cut it off for hour or so you have to go through the same thing all over. Thanks in advance for any help!
Dale
TomTX
05-07-2006 10:27:15
 Re: Hard to start MF65 Diesel in reply to daleevr, 05-06-2006 19:45:09
Check compression first. Solve the problem rather than rely on the fluid. Watch out for over use of the starting fluid, the Perkins does not tolerate it well; will easily break the piston around the rings; then its a rebuild. Tom
Bi Dean
05-07-2006 06:14:47
Dale that sounds like either the starter is turning the engine to slow for it to start or the engine is low on compression
