Fuel guage on MF1105
KYfarm
05-06-2006 05:44:11
My fuel guage jumps to full right after the tractor starts and stays there. I have tried to fill it to max a few time hoping to loosen a stuck float, but it just goes to full and stays.
Any help on what is involved in fixing the guage would be helpful.
It isn't possible to test fuel level with a steel rod like in my other tractors because the fill neck into the tank has two 90s in it.
Thanks for any help!
KYfarm
05-07-2006 11:34:03
 Re: Fuel guage on MF1105 in reply to KYfarm, 05-06-2006 05:44:11
THANKS that is exactly the information that i was hoping to get. I will look at those items next time I have a spare moment.
Thanks again!!
jogl
05-06-2006 15:15:10
Also, if there is a ground wire going up to the sending unit or grounding the tank clean it up real good too. On some tractors the tanks are on rubber isolators so you need a good ground wire going up to the sending unit. I have had ground problems on fuel guage senders on both our 175 and 285.
Good luck, JP.
Aaron Ford
05-06-2006 05:54:50
Sounds like you have an open or short in the fuel level sensor circuit. Fuel gauges work like ohmmeters in that they measure resistance to ground. In your tank you have a variable resistor that rides the float. So, if you have an open it will either read all the way full or all the way empty. If you have a short to ground it will read exactly the opposite. Check out the wire going from the gauge to the tank. If you cannot find anything wrong, remove the sending unit and check it out. The good news is, it sounds like your gauge is working fine. HTH, Aaron
