positive down pressure on hitch
slat
05-03-2006 07:39:39
Is there a way to make the floating hitch on a MF 65 into or a part time positive down force hitch?
mn.Chuck
05-04-2006 08:14:22
 Re: positive down pressure on hitch in reply to slat, 05-03-2006 07:39:39
original equipment 3 pt hitches do not have down
pressure on any tractor I have heard of. The equipment if adj correctly should do it's own
work. Chuck
Arthur from Tassy
05-03-2006 16:31:28
Hi Slat
If you could let us know what is the purpose or reason for your request, it would be a little easier to advise, but in the case of a posthole digger there is a model sold here in Australia that has a additional hydraulic ram attached along the frame on top and back to a linkage onto the cross shaft which gives some downward pressure for use in very hard soils,
If you are using e.g. a chisel plough in very tough ground make sure that the points are not worn and the frame is level , sometimes it helps to fasten weights to the frame and also reducing the forward speed to an absolute minimum thus keeping the points at the correct angle this will create a greater downward draught then control the depth of the implement with the tractors draught control lever .
Please leave another posting if this isn"t the information that you was after.
Cheers Arthur from Tassy
slat
05-03-2006 20:23:01
 Re: positive down pressure on hitch in reply to Arthur from Tassy, 05-03-2006 16:31:28
I was just wondering if it was something that was really even needed mostly. I know that a few tractors were made this way, but I really don't have a use for it other than grading or using a dirt scoop. I probably won't need it then either.
Thanks Steve
