2705 Clutch
jogl
05-02-2006 07:29:25
I'm about to start into my first 2705 clutch job (24 speed). Anybody have any good advice? Have you just replaced the disc or do you replace the pressure plate and resurface the flywheel?
I have the I&T manual. Is there any better info available on line? (ie.: more pictures)
I also need to adjust or repair the transmission brake. Does an adjustment usually work or will I have to replace the friction disc?
Anything else I should check / do while she is split?
Thanks, JPG.
marlowe
05-02-2006 19:23:53
 Re: 2705 Clutch in reply to jogl, 05-02-2006 07:29:25
first get a MF repair manual that I&T is junk. resurface fly wheel replace disc and you might have to replace or rebuild PP [springs brake and face like to crack GHECK IT OVER GOOD but if it was mine i would replace] shop around for the clutch stuff
