pony firing order
Joel59
05-01-2006 05:14:39
I am working on a 1949 Massey Harris Pony that I got that was disassembled partially. The distributor cap and wires were not on the tractor, and now I am trying to put new ones on. I have no idea what position the cap should be in or what wires connect to what cylinders. Can anyone help me with this? Thanks
jjcomp77
05-01-2006 13:31:37
 Re: pony firing order in reply to Joel59, 05-01-2006 05:14:39
Hi Joel First take the front plug out put your finger in the hole turn the motor over by hand with a crank or have somebody turn for you until you get pressure coming out the hole that should be number 1,take the cap off and see which one the rotor is pointing to thats number one the cap . Start there and go 1 3 4 2 around the cap CW and hook up wires to coresponding plugs. Hope this helps John
