MF 135 3 point hitch
davek603
04-29-2006 17:43:32
Hello,
I have a MF 135 which the 3 point hitch drops when the tractor is shut off and when you start it it raises all the way up. It dosent matter what postion the controls are in this happens. It also sometimes acts "jumpy" when you put weight on the arms as it raises. It also appears to have water contamination in the fluid, the dipstick is showing milky oil on it. Any ideas.. Thanks in advance Ave
Big Dean
04-30-2006 06:57:46
 Re: MF 135 3 point hitch in reply to davek603, 04-29-2006 17:43:32
Your pump control valve is hung in the raise position it could be the roller has popped out of the pump control valve lever they will do that now and then or the valve has some trash causing it to stick that is the most common things that causes that problem. There is a possibility it could be something in the control linkage broke or bent. If I can be of further help email me.
