MF digger Backhoe
Joe F
07-03-2000 14:09:04
I have also got a problem with my MF digger Back Hoe. The arm pivots round under its own weight when I release the lever I have a slight oil leak from the `cannister` which rotates the arm, does anyone know how this cannister works - is it simply a stub hydraulic ram inside or a hydrostatic motor? and is it possible to fit new seals? also I suspect the hydraulic pipes have been reversed, would this effect operation? or could it be something else?
Thanks Joe
Big Dean
07-03-2000 16:36:36
 Re: MF digger Backhoe in reply to Joe F, 07-03-2000 14:09:04
The swing cylinder on the Massey hoe is a rotary cylinder. You either have some bad seals or a scored barrel. If you want to email me I will tell you what is involded in replacing the seals.It get a little drawn out for here.
Matt Faudree
01-30-2001 21:40:57
 Re: Re: MF digger Backhoe in reply to Big Dean, 07-03-2000 16:36:36
I am in need of a parts list and a reliable place to purchase parts for my swing motor MF50 Backhoe 54A The (poppit valve) it relives preasure when you move the backhoe bucket all the way to one side or the other and o-rings and seals. Any help would be great.
