100 series 3-point lifts on its own
MF Poor
04-28-2006 06:49:06
"72 MF 150, the 3-point wants to slowly raise (when using position control) while bush hogging. Gotta keep one hand on position lever all the time. Oddly enough, it does it more if and when I"m backing up. I made certain the top-link had plenty of slack. In fact, the lift raises WITHOUT the top link attached.
Normally, it raises just an inch or so, but last night, while using it, the lift raised all the way up on its own once. Not a safe thing at best.
Christos
04-28-2006 09:21:21
 Re: 100 series 3-point lifts on its own in reply to MF Poor, 04-28-2006 06:49:06
MF Poor, it might be that the springs are out of adjustment and then they migrate down to cause it raise.
I'm guessing its stupid whatever it is. I'm sure big dean knows more.
Christos
Big Dean
04-28-2006 09:08:30
The MF100 series the Draft control lever need to be in the fully raised position when using the Position control lever If not that may be causing your problem. If you do have the Draft control lever in the fully raised position then you have a master control spring problem.
MF Poor
04-28-2006 18:49:43
 Re: 100 series 3-point lifts on its own in reply to Big Dean, 04-28-2006 09:08:30
Big Dean, I"ll spend a few minutes looking over your CD tomorrow on this subject. Until then, would a LOOSE master control spring be a likely cause? I can"t seem to keep it where I think it"s tight enough.
Yep
04-28-2006 07:16:47
Hi Mr MF Poor
I control height with draft control Position control down
I put response control to fast
If the mower hit hard object it will raise immediately and avoid possible damage to the mower
and tractor.
Each operator has his own method
and may vary.
Have a good day
Yep
