Massey Harris 55 V-8
Ian Johnsen
04-27-2006 22:24:35
I've got a picture of my latest project in the tractor photo section. Let me know what you think.
Ian Johnsen
04-30-2006 11:53:54
 Re: Massey Harris 55 V-8 in reply to Ian Johnsen, 04-27-2006 22:24:35
I had only enough room in my frame to run the bellhousing behind my motor, but I have seen a 44 where the guy had enough room to fit a truck 4 speed behind his motor. It sure made for a lot of gear choices. If you don't have the depth to fit in a complete trans, I would recommend getting a Lakewood scattershield. They are made if 1/4" steel and can be welded to make your adaption. Plus, you end up with great flywheel safety any club can appreciate. I found my stock radiator was more than adequate, but I had to run an electric fan because the waterpump sat much lower on the BBC than the Continental 382.
rich62
04-30-2006 23:30:57
 Re: Massey Harris 55 V-8 in reply to Ian Johnsen, 04-30-2006 11:53:54
Thanks!
Rich62
04-30-2006 08:03:56
I'm thinking of putting a Y-block Ford with 3 deuces into a Massey 33. Any advice or comments? I have the engine and could get the 33 chassis cheap.
