PTO Engagement
daleevr
04-27-2006 17:21:10
I split my mf65 in half, flushed it out and put it back together with new fluid. I also had removed the PTO lever and cover. When I installed it back at first the PTO was not running. Now it is in ground speed and will not come out of groung speed and will not work in live PTO mode. It is in ground speed all the time. What did I do wrong. Also can I remove the PTO cover without losing fluid, does it come that high up?
Thanks,Dale
marlowe
04-27-2006 17:47:48
 Re: PTO Engagement in reply to daleevr, 04-27-2006 17:21:10
pull the cover because you missed the dog for the pto . park the tractor with the left side up that way the oil will move to the right side and not leak
daleevr
04-27-2006 17:58:33
 Re: PTO Engagement in reply to marlowe, 04-27-2006 17:47:48
I hope I understand correctly. The end of the PTO lever (dog) goes into the, what looks like a pulley a belt would run in correct! And thanks for the reply
Dale
marlowe
04-27-2006 18:43:33
 Re: PTO Engagement in reply to daleevr, 04-27-2006 17:58:33
you got it
