bucket float
Tod
04-27-2006 17:09:30
I"ve got an MF40 with the mf32 loader - Is there a "float" position setting for the front loader?
thanks,
GaryF
04-30-2006 19:48:12
 Re: bucket float in reply to Tod, 04-27-2006 17:09:30
Float and auto level were available. However not all control valves had either or both of these features(so says the parts manual)
Teighs
04-28-2006 04:22:54
When I got my MF175 with the MF32 Loader, someone had the lines reversed. I could "float" the bucket curl but not the boom. So I reversed them back and now everything is fine. Maybe you have the same problem?
Big Dean
04-27-2006 18:58:56
Yes, there is a float position the lever for raising and lowering the loader when you push the lever part of the way forward that gives you down pressure when you push it all the way forward that is the float position you can or should be able the feel it snap into the float position.
