255 clutch adjustment
fixitforfree
04-23-2006 19:42:55
How is the clutch adjustable on a 225 Massey? My friends is slipping so bad it will barely pull itself in Low-low at all. If you hold the brake it will stop the tractor. But, it goes into gear easily without scratching at all so I assuming it needs to be adjusted. Can you go in a "window" at the bottom of the tranny to do this? What needs to be adjusted and how if I do this? Thanks for any pointers.
wombat2
04-25-2006 20:17:11
 Re: 255 clutch adjustment in reply to fixitforfree, 04-23-2006 19:42:55
On the MF135 adjustment through the bottom access plate is to adjust the 2 stage clutch which operates the PTO and hydraulics. Adjustment to the main clutch is via the pedal position. Yours is pobably similar. Check Big Deans site for more info.
weekend mechanic
04-24-2006 02:23:36
how much does the clutch pedal have free travel before the clutch dis-engages? if there's very little or no free play or travel in the pedal then you might be able to fix it by adjusting the free travel on the linkage. If there is some slack thoght, then there is some other problem with the clutch, propably the disk is worn out, and the tractor would have to be split to fix that.
fixitforfree
04-25-2006 18:39:12
 Re: 255 clutch adjustment in reply to weekend mechanic, 04-24-2006 02:23:36
I will have to check the pedal free play to be sure. If it is ok, doesn't the clutch have some adjustment through a bottom "window" in the transmission?
