TO 35 CARB. SETTING
james in ky
04-22-2006 08:05:38
Hi, I am needing help setting the carb. on my to 35. Does anyone have the settings for me?And also why would I have a dead plug I was disking and it started to miss and found a plug dead,only after having the carb cleaned. Thanks
Jerry/MT
04-22-2006 10:01:07
 Re: TO 35 CARB. SETTING in reply to james in ky, 04-22-2006 08:05:38
I can't help you with the carb setting. Regarding the "dead plug", I presume you mean it's not firing. If so, check the wire where it goes into the distributor cap. Make sure that there is no corrosion and that the little brass clip is in place touching the copper wire. Do the same with the plug end. Check the plug insulator and make sure that it's not cracked and that the gap is correct. Check the back side of the cap and make sure that the piece the rotor touches is not corroded or broken. Look for carbon tracking or cracks in the cap. Make sure the rotor is good. Look at the distributor cam and see if a lobe is worn or the distributor shaft/bushing is worn. Finally, check the compresion on the dead cylinder..
