Bucket Wont Lift MH50
ohiopicker
04-22-2006 05:45:14
I replaced my foamy hd oil with 8 gal new 90wt mineral oil. The 3 point will operate ok but my bucket won"t lift. I think I took about 9 or 10 gal of old oil out but what I saw here was it took 8 gal. Just a little oil shows on the spike they have for a dip stick. Any suggestions? I didn"t want to over fill my tractor so I don"t know if I should put more oil in. The controls are mounted up on the right side arm and there is a little knob on a rod that I push or pull in front of the seat to select the bucket or 3 point if that helps. Thanks
Big Dean
04-22-2006 14:55:22
 Re: Bucket Wont Lift MH50 in reply to ohiopicker, 04-22-2006 05:45:14
Are you lowing the lift arms just an inch or 2 before you switch the diverter valve into the position for the loader and then moving the position lever in the fully raised position. If the lift arms are completely up that will shut the pump down. If this does not help Email me and I will try to help you with it.
Randy165
04-22-2006 06:29:59
90 weight??? That"s seems very heavy for the hydraulics! Most hydraulic oils are closer to 15 or 20 weight.
C. T. in Oklahoma
04-22-2006 10:27:11
 Re: Bucket Wont Lift MH50 in reply to Randy165, 04-22-2006 06:29:59
Randy, My book calls for 90 weight for my MF35, wouldn't surprise me if the MH50 uses the same.
C. T.
