outer axle seals MF65
kazenza
04-15-2006 14:16:23
I've got my planetary apart, and I'm considering replacing the outside axle seal. The service manual shows that you need to press the axle out of the planetary and that you need a special tool to reinstall it without damaging the new seal. Anyone else with experience with this particular maneuver. Randy
kazenza
04-15-2006 17:27:15
 Re: outer axle seals MF65 in reply to kazenza, 04-15-2006 14:16:23
Did you have to use a press to remove the axle? If you don't have to press it on, I'm not sure why you would need to press it off. Randy
mhmalcolm
04-15-2006 15:52:43
I have done this job several times without the special sleeve. Just wrap a single layer of plastic electrical tape around the axle just at the edge of the seal surface, covering the sharp edge of the splines. Generously grease the seal and shaft, then oil them with hydraulic fluid. Lower the housing with the seal installed in it over the shaft and rotate it back and forth while lowering it over the taped spline area until the seal is down on the sealing surface of the shaft, then peel off the tape and continue the reassembly. I have been around one of the tractors I did this on 20 years ago on and off and it still doesn't leak.
