Hydraulic cover regular diesel
daleevr
04-15-2006 10:44:00
Can anyone tell me how hard it is to remove the top cover to get access to the hydraulic pump. Is there a lot to undo before it will come off and how about putting it back on, critical or not?
Thanks
Dale
Aaron Ford
04-17-2006 17:56:29
 Re: Hydraulic cover regular diesel in reply to daleevr, 04-15-2006 10:44:00
It's heavy as h**l!!! Get help. Be careful as the hydraulic fingers will be engaging/disengaging the pump when it is lowered or raised.
DavidP, South Wales
04-17-2006 13:48:04
There is not a great deal to undo. The line of bolts around the outside hold the cover down. Do NOT touch the four nuts on the top. There is a special lifiting tool available which allows you to do it safely. It can be lifted off with a hoist or similar but refitting lacks the alignment of the tool To do the job properly the adjustments should be carried out first. Buy a good shop manual, it will be well worth it.
David
daleevr
04-15-2006 10:46:36
 Sorry, above is a MF 65 in reply to daleevr, 04-15-2006 10:44:00
MF 65
