to-35 hydraulic lift
sooners
04-15-2006 07:05:42
My to-35 lift dosent seem to be lifting as high as it should. In the down position its about 6 inchs off the ground and in the up position its about 2 ft off the ground. Should it have more travel then that? It also bleeds down when you turn the motor off. thanks
Big Dean
04-15-2006 20:38:47
 Re: to-35 hydraulic lift in reply to sooners, 04-15-2006 07:05:42
The lift leaking down is fairly normal on those old tractors it is cause by a leak in the hydraulic system someplace. There is an adjustment to set the lift arm height If you will send me an email address I will send you a picture showing how to make that adjustment
