Transmission break down on a model 35 M/F
Roger Earl
06-29-2000 17:48:01
I have Massey-Ferguson tractor and the main drive shaft is broken and I would like to know how to break transmission down to get to the main shaft. Thank You.
Gregg
07-01-2000 04:10:31
 Re: transmission break down on a model 35 M/F in reply to Roger Earl, 06-29-2000 17:48:01
There is a large cotter pin on that sleeve, when you remove the pin you can slide the sleeve forward, then the drive shaft can be slid rearward and out from the transmission, you must do this if you are removing the hydraluic pump also, good luck!
Richard
06-29-2000 19:26:49
Is it the coupler to the rear end or the input shaft?
Ali Widaa
11-17-2000 22:57:43
 Re: Re: transmission break down on a model 35 M/F in reply to Richard, 06-29-2000 19:26:49
Dear sir/madam I'm going to do my M.Sc. research on Tractors break down for that I ask your help to supply me by information and litrature related to my topic.
tours sincerely
Ali Widaa
adress
Sudan
University of Khartoum-Faculty of Agriculture Dept. of Agric. Engineering
P.O.Box 32
postal code 13314
Shambat
Roger Earl
07-01-2000 00:08:10
I am new to this game ok,,so bear with me,,,,we opened the plate right below the seat area on what would be the passanger side,,,as the fluid drainedwe saw a shaft that had a sleave around it ? The sleave is about6 to 7 inches long that went over a shaf There is a grove that runs around the sleave and that is what snaped on me. Any info you can send to me would be of great help. thank you roger
Richard
07-01-2000 20:24:24
 Re: Re: Re: transmission break down on a model 35 M/F in reply to Roger Earl, 07-01-2000 00:08:10
Don't weld the sleeve and the new sleeve must have a groove cut around it also. This sleeve keeps you from buying expensive ring and pinion gear sets.
